John Bonnett
| posted on 26/3/23 at 12:40 PM |
Type9 clutch cable lengths
The clutch cable I'm using has an eye for a clevis pin and the outer is about 920m long. I can find no record amongst my purchase invoices of the
cable but I would like to know what vehicle it's from so that I can buy a spare.
I would be grateful if anyone could post a list of type9 clutch cable lengths please but only those with an eye at one end..
Thank you
John
big_wasa
| posted on 26/3/23 at 03:43 PM |
I trawled eBay, Burton power ect and just compared escorts, capris, cortina’s, granadas and so on.
John Bonnett
| posted on 26/3/23 at 04:30 PM |
I've just done the same thing but cannot find the lengths on the Ebay ads. Burton list and extra long cable with a length and hat might do. I
just need to ask them what length the outer is.
Many thanks for your reply.
John
John Bonnett
| posted on 27/3/23 at 08:10 AM |
Just to complete the story, I've just called Burton and the extra long cable has an inner length of 1230mm and the outer 950mm which is pretty
close to what I have fitted so I've ordered a spare. Job jobbed!
tims31
| posted on 28/3/23 at 07:39 AM |
I think the code quoted in replacement part listing relates to the cable length or at lest did in my case. I fitted a QH replacement part which was
quoted as QCC 1148 and is 1148mm in length but also another companies code was BC1148 and these are Capris Mk II/III cables
Build: http://www.martinsfurybuild.co.uk/
John Bonnett
| posted on 28/3/23 at 08:30 AM |
Good information. Thank you. I needed the longest cable I can get to give a smooth run and the one I've ordered from Burton is very similar to
the one already fitted which is fine.
| posted on 28/3/23 at 01:52 PM |
Seem to recall using a Capri clutch cable on my MK Indy (Pinto with Type 9 an MK supplied pedals). I think I needed the length to get a smooth enough
curve betweeb bulkhead and gearbox.
John Bonnett
| posted on 28/3/23 at 03:30 PM |
Yes that's the problem I have Nick but there is also the exhaust manifold to contend with which is on the driver's side on the Sigma.
johnemms
| posted on 28/3/23 at 07:03 PM |
Ford Cortina Left Hand Drive Cable ... Maybe?
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
John Bonnett
| posted on 28/3/23 at 07:11 PM |
I don't know if it's for a lhd car but this is the one I have and it is fine
https://www.burtonpower.com/clutch-cable-ford-cortina-mk3-mk4-1-6-2-0-sohc-pinto-to-8-79-qcc1010.html
| posted on 29/3/23 at 09:31 AM |
Hi John,
I had the same issue in my MK iNdy (Pinto engine, so exhaust on the RH (Drivers) side). I had to secure the clutch cable clear of exhaust manifold
with a rubber lined metal P clip. Worked OK and it didn't suffer. I did cover the tubular exhaust manifold with heat wrap as well, which
probably helped avoid too much heat.
[Edited on 29/3/23 by nick205]
John Bonnett
| posted on 29/3/23 at 12:00 PM |
Hi John,
Hi Nick,
You've made a really neat job of insulating the manifold and that's something I shall definitely need to do both for the clutch cable and
the steering column U/J which are both very close to the manifold.
