big_wasa
| posted on 22/2/05 at 10:17 PM |
Dif ? Dif ? Dif ?
Does anybody know if the sierra dif will fit the capri atlas axle as the one I have is passed its best...its a 2 ltr s 52" wide job.
The pin that goes through the dif has rounded out the hole in a big way......
Or has anybody got one going cheap ?Or should I just scrap it???
Any help would be good please ????/?
| posted on 22/2/05 at 10:20 PM |
id be plesantly suprised if it did - they seem very different. plus, beam axles with LSDs are usually very expensive, i would expect them to be less
expensive if you could just bang a sierra LSD in.
good luck though
Ben_Copeland
| posted on 23/2/05 at 09:03 AM |
I agree.. cant imagine a solid axle diff being anywhere near the same as a independant rear diff
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
| posted on 23/2/05 at 01:58 PM |
No won't fit to wide across the bearings but I have seen it done the otherway Escort koln diff in Sierra casing using spacers ----
don't ask horrendous bodge (not mine) and I don't how long it lasted.
