Bob the Builder
| posted on 4/3/05 at 12:21 PM |
Uprights + Ball Joints
Hi all,
This is probably a very sill question (please forgive my stupidity), but......
How tight should the nuts be on the tapered bit of the ball joints my cortina uprights fix to?
I presume they should be quite tight, so the ball joint rotates with the upright when steering - ie the upright doesn't just turn on this
tapered bit.
Rob
tks
| posted on 4/3/05 at 01:16 PM |
well
i just give it a full and pair of good swings with my "ratle??"
don't forget that some parts move when trying to fix, you should then presit with a good force in wards... (soow the nut comes lose..)
TKS
clbarclay
| posted on 4/3/05 at 01:40 PM |
On a ford sierra the book says 65 to 85 Nm (48 to 63 foot pounds) for lower ball joint.
Escort mk 2 is about 50 Nm (30 to 35 foot pounds)
[Edited on 4/3/05 by clbarclay]
| posted on 4/3/05 at 02:41 PM |
For the ball joints it roughly translates to a damm good pull on a standard length socket ratchet.
For the trackrod ends just an ordinary good pull will do.
carnut
| posted on 4/3/05 at 07:54 PM |
A good thing to do when putting something onto a taper is to use a plane nut to pull it onto the taper then take off the plain nut and refit with
nyloc etc.
| posted on 4/3/05 at 08:19 PM |
I think you mean ratchet TKS. Just be careful not to overdo it as it's possible to get over 100lb/ft with a ratchet handle. I had a bottom
balljoint strip on me once and I suspect it was because I was too enthusiastic tightening it up and weakened it in the process.
