smac
| posted on 7/3/05 at 08:03 PM |
Master Cylinder ID
Nothing comes out of the front port on the MC of my part built MK locost meaning no front brakes. Is a home rebuild possible or is replacement the
best bet? Thing is Ive no idea what it came from - its attached to a servo (are there servo and non servo MCs?)and is marked:-
3212 474C Q81 with OP or CP on the other side. Can anyone help?
Simon
| posted on 7/3/05 at 08:25 PM |
Could be a few things things -- (1) the front piston in th master cylinder is stuck at full travel or (2) the recuperating seal in the front circuit
is goosed or (3) the pedal push rod isn't allowing the master cyilnder piston to fully return..
(1) remove and drain master cylinder and try blowing back the piston with low presure air (take care) -- if that dosen't work strip the
cylinder.
(2) is the easiest to check take the lid off the master cyilder and get some body to push the pedal down --- the the fuild level rises slightly the
seal is gone.
(3) is very common on home built cars with home made master cylinder push rods.
smac
| posted on 7/3/05 at 08:53 PM |
Well Ive taken the cylinder off and the front port still does nothing which I think discounts (3) and I didnt notice (2) happening before so I guess a
strip down is in order - presumably to get a refurb kit Ill have to know what MC it is - how can I find out?
clbarclay
| posted on 7/3/05 at 08:59 PM |
try taping the code into an internet search.
smac
| posted on 7/3/05 at 09:05 PM |
Yep been looking for a while but nothing yet.
clbarclay
| posted on 7/3/05 at 09:36 PM |
Try getting hold of a new (scond hand from a known donor car) MC of near equiverlant spec. to the one you already have.
smac
| posted on 8/3/05 at 12:12 PM |
Weel still no luck on the interweb. Im gonna take it to the scrapperrs I try and find one that look the same.
