DaveFJ
| posted on 16/3/05 at 12:14 PM |
Fitting Princess calipers
Tried fitting the Princess calipers to my cortina hubs lats night, after much swearing I realised that i had forgotten the spacers that were supplied
in the kit.
Now they are fitted I am a little worried about the bolt length, I currently have the standard caliper mounting bolts from the donor but with the
addition of a spacer between the caliper and the upright I am wondering if the bolt is engaged enough? I estimate i have lost about 3mm if I do not
put washers under the bolt heads (yuk)
What have others done ? should I fit longer bolts ?
Dave
NS Dev
| posted on 16/3/05 at 12:57 PM |
I doubt it will do any harm as it is, but they are only M12 std thread aren't they? (IIRC!) If so, you might as well put some longer ones in,
then you don't need to worry!
