Hornet
| posted on 17/3/05 at 09:27 PM |
Resevoir for master cylinder
Hi guys... I'm looking for help... I need a resevoir that will fit a mk 2 escort master cylinder (Girling). It needs to be horizontal and not
inclined like the original.
Anyone know which kind fits it?
Cheers in advance.
ops sorry for size
[Edited on 17/3/05 by Hornet]
bigbriglasgow
| posted on 18/3/05 at 07:59 AM |
Can you not just park yr car on a very steep hil when you want to check the level?? failing that lift the fron of the car up high and do it??
clbarclay
| posted on 18/3/05 at 11:13 AM |
I am planning on floor mounted pedals and using the origional escort MC.
My plan is to use a basic MC reservoir (yet to be sourced) mounted higher up and connected to the escort MC by flexible pipes, that should fit nicely
into the MC holes.
This plan may need stiff plastic pipes (similare material to reservoir) going into the MC and the flexible pipe slid and help over it.
In short with the reservoir mounted seperately it can be mounted at any angle, so even the escort reservoir could be used.
