scoobyis2cool
| posted on 22/3/05 at 05:36 PM |
Cable banjos
I'm not having much luck with my clutch at the moment, the cable banjo broke a while ago and I managed to bodge it, but now the cable has worn
through so I've decided it needs a rethink.
My current banjo looks like this:
  My cable banjo
but the end piece completely sheared off from the main body, I think this is because I had to drill the hole a bit bigger to get my cable to fit,
which must have weakened it.
I've also seen a design like this:
  Cable banjo
This might be a better bet as long as the hole is big enough. My cable is about 3mm in diameter but really I need the hole to be about 4mm to account
for frayed ends etc.
Does anyone know where I can get these? If not, any alternatives i could try that don't involve welding?
Thanks,
Pete
[Edited on 22/3/05 by scoobyis2cool]
macspeedy
| posted on 22/3/05 at 06:07 PM |
ask mangogroove he has one he may be willing to part with
shortie
| posted on 22/3/05 at 07:01 PM |
MK do them and so do MAC1, I got mine from MAC1
Rich.
scoobyis2cool
| posted on 22/3/05 at 07:10 PM |
Thanks for the suggestions guys, Rich, do you have any photos of the ones you got from MAC1? If not, are they the same as either of the pics I posted
above or something different?
Pete
Mark Allanson
| posted on 22/3/05 at 07:26 PM |
Clobber your local AA man, there carry every cable end imaginable in the van, and a couple of reels of cable. The ends are grub screw secured to make
it economic repairing at the roadside
scoobyis2cool
| posted on 22/3/05 at 08:24 PM |
Yeah I've heard the AA have stuff like that, do you reckon they would actually sell me one or would they just stare at me with a look of
distain?
Pete
clbarclay
| posted on 22/3/05 at 09:26 PM |
Just pretained to break down and leve a couple of bits of cable with threaed ends under the bonnet.
They might just stare at me with a look of distain if you did that as well.
Danozeman
| posted on 22/3/05 at 09:43 PM |
Alot of them aa blokes are reasonable if you catch them when they start there shift. Bung em a quid and youl get one.
Dan
Mark Allanson
| posted on 22/3/05 at 10:01 PM |
Most are car nuts, tell you are building you own car out of metal sticks, they would probably be pleased to help
James
| posted on 23/3/05 at 10:38 AM |
Pete,
I'm using a Capri (3 litre IIRC) adjustable cable. It has a banjo built into it.
Cost about £3 from an autojumble I think.
HTH,
James
- Muhammad Ali
scoobyis2cool
| posted on 23/3/05 at 11:22 AM |
Thanks for all the suggestions, might go on the hunt for an AA van later. The worst part is the weather is REALLY nice here today, perfect weather for
taking the car out, and it's stuck in the garage
James, do you have any photos of your cable? Does it fit to a type 9 easy enough? Does it just bolt to the pedal or do you need to weld it on?
Pete
scoobyis2cool
| posted on 23/3/05 at 04:54 PM |
Update: managed to bodge the old cable and connector, not sure how long they'll last but on a quick blast round the block it felt pretty
good.
Got a new cable with integral banjo on the way courtesy of MAC1.
Pete
| posted on 24/3/05 at 11:10 AM |
Does the cable swivel at the pedal end or is it bolted on tight?. If it's bolted it frays as the angle changes, nephew had this problem. If you
cut the cable with a proper Bowden cable cutter you won't get frayed ends, ask at a cycle shop they usually have one.
[Edited on 24/3/05 by Peteff]
scoobyis2cool
| posted on 24/3/05 at 11:22 AM |
Another update
I ordered a new clutch cable from MAC1 less than 24 hours ago and I've got it already! Uploaded a few photos to my archive if anyone's
interested, now off to fit it and go for a burn
Pete
scoobyis2cool
| posted on 24/3/05 at 11:25 AM |
Hi Pete, yeah I did have mine bolted tight so it wouldn't swivel. Didn't cross my mind until it frayed and broke and then I realised what
a fool I'd been!
Have just got my new one in the post (see above), so I'll make sure it DOES swivel this time - let's hope this is the end of my clutch
problems. I'm sure something else will break to make up for it though...
Pete
| posted on 24/3/05 at 05:54 PM |
Tip for cutting bowden cable without fraying if you have no bowden cable cutters is to use a sharp chisel , place the cable onto an anvil /vice or
other suitable block , lay the chisel across cable at point to be cut and give the chisel a sharp tap. Used this method in a motorcycle workshop even
when bowden cable cutters were available, works a treat
James
| posted on 29/3/05 at 07:29 AM |
Pete
Only just spotted this- sorry!
Yes, it does bolt straight up to the Type 9 (even more so when you do it correctly the 2nd time! ). Indeed, the other end does just bolt to the
pedal.
Glad you sorted it though.
James
- Muhammad Ali
