timwest167
| posted on 6/4/05 at 10:09 AM |
Sierra Column Mounting
Just wondering on the best methods of fixing the steering column to the mounts on the chassis. The sierra column has big holes in the mounting
bracket and I don't really want to buy the tophat reducer things (more expense). What have other people done... just used massive bolts!?
Tim
James
| posted on 6/4/05 at 10:49 AM |
Tim
Nah, just small bolts (m8?) but large washers!
If it was good enough for 60K miles of Sierra it's good enough for me!
James
- Muhammad Ali
| posted on 6/4/05 at 11:05 AM |
i filled the hole with a nut, and then a washer and nut to finish it off - the bolt i welded to the chassis.
DaveFJ
| posted on 6/4/05 at 11:19 AM |
bolts from behind with 2 plain nuts on the mouinting side which fitted perfectly into the column mounts, then large washers under the fixing nyloc
nuts to make everything look pretty...
Dave
craig1410
| posted on 6/4/05 at 12:02 PM |
I just used the large and very thick washers which were fitted to the donor vehicle for the same purpose. I used M10 bolts and nylocs.
Craig.
