| posted on 23/4/05 at 11:18 PM |
is this column collapsed
im sure we have had this debate before, but does anyone know if the adjustable column pictured below, has been collapsed. And would it still be usable
if it had? It came out of an undamaged car, im just wondering if i was a little too persuasive with it... Cheers.
Cheffy
| posted on 23/4/05 at 11:27 PM |
Hi Joel,
You're right, it has been discussed before. No I don't think it has necessarily collapsed. IIRC the consensus of opinion the last time
someone posted a similar photo was that this isn't the collapsible part of the column. The collasible part is the triangular section of the
column further down. In the event of a frontal impact the clamp on the triangular section can slide up the shaft. Er, if you see what I mean!
I think that's correct, I could however be shot down in flames!
Martin.
Farts are like Rock'n'Roll. You love your own but you hate everybody else's. Lemmy, Motorhead.
Avoneer
| posted on 23/4/05 at 11:57 PM |
Yep Joel - it's fine and how it should be.
That is how the "adjustable" columns look.
It's the non-aqdjutable ones that have the same sort of section that doesn't look squashed.
Pat...
| posted on 24/4/05 at 12:03 AM |
great news - seeing as ive already sold and posted it!!!!
cheers guys.
wilkingj
| posted on 24/4/05 at 09:54 AM |
Ive looked and thought about it,
I believe its OK, the others say they are like that, and Joel says not from a damaged car.
I have both adjustable and non adjustable.
Logic says the bit we are discussing collapses when the driver hits it in an accident. The lower traingle bit is for forces coming from the other end
of the column.
LOOK at the mounting points and the concertina bits. The std one has the concertina bit ABOVE the mounting point and would collapse to become
shorter.
The Adjustable one has a "collapsed" concertina bit and its mounted BELOW the mounting point and the drivers force would EXTEND the
concertina bit in an accident. ie the both do the energy absorbtion bit, bit in opposite ways due to the mounting positions... Does this make
sense?.
I was not sure, as I have never seen the adjustable one before. At least we know its not from an accident damaged car and should look the way it
does..
A little thought and discussion throws a little light on it
[img]/upload/DSCF0052.JPG[/img]
If you cant see this here, its in my Archive under the Viento build folder
[Edited on 24/4/2005 by wilkingj]
Best Regards
Geoff
http://www.v8viento.co.uk
| posted on 24/4/05 at 10:10 AM |
The collapsible bit is the triangular section that slides into the bit you have there Joel.
wilkingj
| posted on 24/4/05 at 10:59 AM |
I believe there are two collapsible sections. The triangular section in the lower half to absorb and movement / body shortening in the engine bay area
in a crash.
And the Bit in the passenger compartment to absorb the driver hitting the column in the event of bulkhead movement or the back end of the car crushing
thus moving the driver on/into the column.
Best Regards
Geoff
| posted on 24/4/05 at 01:18 PM |
sometimes the lower triangular bit has a hole in it, which engages with a spike on the downlink - hence in some cases this bit couldnt collapse.
viatron
| posted on 24/4/05 at 08:25 PM |
Thats fine, mine is identical and i took it out of my donor once i had driven it home!! Have also checked another one with adjustable column in the
breakers next door and it is also the same.
Mac
wicket
| posted on 24/4/05 at 08:42 PM |
The spike is to locate the down link clamp and does not stop the sliding/collapsable section from moving.
Cheffy
| posted on 25/4/05 at 08:11 AM |
For what it's worth, mine is identical to Joel's and mine was also taken from a non accident car that was driven home by me.
Martin.
wilkingj
| posted on 25/4/05 at 10:21 AM |
I have reasoned it out (above thread)..
It was a bit worrying, when you have one concertina extended and one not, and you know thats the collapsible section
Thanks for all the replies.. I will sleep better now!.
Best Regards
Geoff
