Author: Subject: Steering coupling - escort MK2 rack
Paul (Notts)
posted on 5/5/05 at 09:01 PM Reply With Quote
My lower steering down link ends in a rubber disc type link conecting it to the steering rack. I dont like the look of it or trust a 20 year old lump of rubber with my life!.
How hard is it to replace it with a steel UJ type joint.
How do I remove the old link. I notice that the end of the column is splined. If I heat up the old link and try and tap it off will this work?
Any ideas?
flak monkey
posted on 5/5/05 at 09:23 PM Reply With Quote
The rubber disc joint is held on with a pinch bolt. Just undo it and tap it off.
You can buy all steel UJ for the escort rack from people like rally design. Theya re about £25 and IIRC they are a direct replacement for the rubber disc one.
Sera
http://www.motosera.com
posted on 5/5/05 at 10:22 PM Reply With Quote
You can buy the rubber disc, cut the rivets that hold the old one and replace them with M8 bolts.
