Snuggs
| posted on 15/5/05 at 09:57 AM |
Sierra diffs
I am thinking of swapping my 7" diff for a 7.5" lsd.
Do I need to change the driveshafts ?
Clive
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
mookaloid
| posted on 15/5/05 at 05:57 PM |
I don't know but I have a 7" LSD you can buy from me if you want
Mark
A fulton
| posted on 15/5/05 at 07:02 PM |
diff
Hi snuggs
7.5 lsd will fit if you are on Lobro joints
Andrew
Snuggs
| posted on 16/5/05 at 03:31 PM |
Cheers guys.
Mark, how much do you want for the LSD.
Clive
mookaloid
| posted on 16/5/05 at 04:20 PM |
Clive,
You have U2U
mark
Liam
| posted on 16/5/05 at 09:18 PM |
Careful though - if you're running the little push-in tripode shafts with rear drums you will have to change them too. And the hubs, uprights,
brakes etc.
But if you have a 7" with flanged lobro shafts and disc brakes then you can simply dump the 7" for a 7" lsd.
If you go for a 7.5" lsd (not needed unless you have massive power) you might need to swap shafts anyway if the 7.5" diff is wider than a
7" between flanges. I have no idea if this is the case or not though. I think not.
Ooooh - even if a 7.5" is no wider, if its from a sierra cossie it has bigger pcd flanges than any other diffs and super phat shafts.
Personally i'd avoid 7.5" diffs.
Liam
