Author: Subject: m/c to remote resovoir adapter
ned
posted on 16/5/05 at 04:32 PM Reply With Quote
I've just been on the phone to think automotive and amongst other things I asked for adpaters to go into the holes in the mastercylinders so I can attach brake hose to the remote resovoirs. I understood from one of NS Dev's posts that girling/wilwood (american) master cylinders had 3/8" threads in them, but the guy at think auto said they only supply adapters for 7/16" which sounds a bit on the large side to me as that's the size i use for my seat belt mounts!!
can anyone tell me what they used/asked for and where they got it? yes i did get the blue/purple cotton braided brake fluid resistent hose aswell..
cheers,
Ned.
beware, I've got yellow skin
bigandy
posted on 16/5/05 at 04:33 PM Reply With Quote
Hi Ned,
if you look at this page:
[url=http://www.wilwood.com/Products/006-MasterCylinders/004-CRRMC/index.asp]http://www.wilwood.com/Products/006-MasterCylinders/004-CRRMC/index.asp[/ url]
the non integral master cylinders have an inlet of 7/16" (20t.p.i.) and an outlet of 3/8" (24t.p.i). that's according to the drawing on that page.
I'm after some hose and adapters to go from the reservoir to the master cylinders too.... Where did you get the SVA freindly hose from?
Dammit! Too many decisions....
ned
posted on 16/5/05 at 04:39 PM Reply With Quote
i just ordered the hose from think automotive, its the only stuff they do suitable for brake fluid, i guess i'll just hold onto the packet (assumig it has one) for sva or get a letter fro them with it's specs on nearer the time..
just been reading this old thread following a search:
http://www.locostbuilders.co.uk/viewthread.php?tid=20390
and europa only list a 7/16"unf one aswell..
Ned.
[Edited on 16/5/05 by ned]
posted on 16/5/05 at 05:15 PM Reply With Quote
The Europa hose isn't marked up correctly so will not pass SVA . The Think Automotive hose is marked up with what I hope is the correct part no / spec , certainly looks like the hose that is used by Audi amongst other manufacturers with a blue braided cover
Andybarbet
posted on 16/5/05 at 05:53 PM Reply With Quote
Got my 7/16" adaptors from Burton's for £8 each if thats any help ? fits girling and wilwood m/c's.
[Edited on 16/5/05 by Andybarbet]
wicket
posted on 16/5/05 at 08:35 PM Reply With Quote
Here's another thread on the same (hose)subject,
http://www.locostbuilders.co.uk/viewthread.php?tid=20633
The fittings are 7/16" UNF, also available from Merlin Motorsport
ned
posted on 16/5/05 at 08:41 PM Reply With Quote
thanks guys, i obviously had it wrong! will give thinkauto a call first thing and see if they can add a couple to my order
Ned.
