bigandy
posted on 22/5/05 at 10:47 AM |
Wheel bolt to stud conversion
Morning all,
I've got hold of some conversion wheel studs to convert a fiesta hub from wheel bolts to wheel studs. They are the sort that screw in where the
bolt screws in, and have a threaded section exposed to accept a wheel nut.
Does anyone know how these are supposed to be installed? It doesn't seem right to just screw them in. Should they be locked into the hub
somehow?
Dammit! Too many decisions....
johnston
| posted on 22/5/05 at 01:20 PM |
A good threadlock normally does trick we use in on rally cars incase a stud gets broke and needs changed
or a bit o weld on back would prob be better not likely you'll need to change 1 in a hurry
