Author: Subject: yet more brake woes!!!
Jumpy Guy
posted on 24/5/05 at 08:14 PM Reply With Quote
just fitted new callipers up front, got drums on the back
one side appears to bleed fine, but i cant get any fluid at all to flow on the other side... front right.
bought an eezi bleed amd it makes no difference.
driving me mad because all worked before i swapped callipers....
any suggestions?
Jumpy Guy
posted on 24/5/05 at 08:45 PM Reply With Quote
OK, now if i take the calliper off on that side, no fluid flows from the pipe when i pressurise the system using the eezi bleed..
so, does that mean - air lock in the master cylinder?
Liam
posted on 24/5/05 at 09:00 PM Reply With Quote
Sounds odd. I assume your flexi line is decent and there's no way it is old and possibly blocked?
Must be air in the master cylinder then. Can you pump some fluid through with the pedal? I'm not sure how these easy bleed systems work.
Liam
Jumpy Guy
posted on 24/5/05 at 09:33 PM Reply With Quote
Just solved it!
was using old flexi pipe for SVA since i know there are some problems with braided hoses..
unscrewed flexi and presto- fluid \\!!!
so , knackered pipes it was.
so, if anyone can suggest a good source of braided pipes???
juat noticed that Liam suggested this. well done mate, though if you had been 20 minutes quicker it would have been better!! next time, chop chop!!
[Edited on 24/5/05 by Jumpy Guy]
Liam
posted on 24/5/05 at 09:45 PM Reply With Quote
Sorry!
I'm getting my flexi's made up by MNR. Or you could get all the little bits from someone like rally design and make em up yourself.
Liam
Edit: Hang on - twenty minutes faster would have been five minutes before you posted your second lot of information!
[Edited on 24/5/05 by Liam]
Jumpy Guy
posted on 24/5/05 at 09:58 PM Reply With Quote
EXACTLY!
thats what we need around here - initiative (and a wee bit of predictive power)
On that note, what length of braided do i need?
i have the mountings as in "the book"
the sierra ones always looked a bit long, but i dont know how much 'slack' is ideal??
posted on 25/5/05 at 07:15 AM Reply With Quote
I got mine from
Merlin Motor Sport
Price was reasonable, made-to-measure, and came with crimped ends that are liked by the SVA inspectors (you may have to specify the crimps).
[Edited on 25/5/05 by David Jenkins]
Jumpy Guy
posted on 25/5/05 at 07:47 AM Reply With Quote
I'll give them a bell this morning
if anyone could measure hoses for me it would be appreciated..
i'm using 'book' mounts etc.
thanks!
