<<  1    2  >>
Author: Subject: Cutting a hole in a used fuel tank
ChrisGamlin
posted on 29/5/05 at 09:15 PM Reply With Quote
I need to add a fuel level sender to my ally tank now that Ive got a Digidash (previously just used sight gauge).
So - how do you go about cutting a hole in an ally fuel tank thats previously had fuel in it without risking blowing yourself up?
Staple balls
posted on 29/5/05 at 09:17 PM Reply With Quote
fill it with water
need4speed
posted on 29/5/05 at 09:22 PM Reply With Quote
Pump exhaust gas into it is another way.
Dave
ChrisGamlin
posted on 29/5/05 at 09:29 PM Reply With Quote
Yep have heard the exhaust gas one before, the only problem I have is that apart from the kit car (which obviously cant run without a tank!), the only petrol engine I have is the lawnmower, the tintops are both diesel
Whats the best/safest way to cut it do you think, lots of small drill holes then file the remainder? ive also got the option of a jigsaw, I dont think ive got a suitably sized hole saw tho
clbarclay
posted on 29/5/05 at 10:37 PM Reply With Quote
Its probably a non starter idea because of all the half moons that would end up in the tank, but a nibbler should have no ignition risk and be able to make large holes of any size/shape.
craig1410
posted on 29/5/05 at 10:44 PM Reply With Quote
Does aluminium create a spark when you cut it? I've never seen that happen before. I agree better safe than sorry though.
What about filling it with CO2 gas from a pub gas or halfords welding gas bottle first? If it was me I'd probably just fill it with water to be honest. You can always dry it out later by gently heating and ventilating the tank. It's not as if it is a particularly complex shape like some cars and should be easy enough to dry out.
Craig.
Cita
posted on 30/5/05 at 07:41 AM Reply With Quote
The smallest opening will cause the gas to excit leaving the heavier fuel damp in the tank.(I think...)
Add some aluminium sawdust is allways good to make better explosions
Water is the cheapest and safest method except that you can get electrocuted but that's a minor problem compared to tank explosion
gazza285
posted on 30/5/05 at 08:19 AM Reply With Quote
A little bit of water with washing up liquid in it, fill the tank with bubbles.
tks
posted on 30/5/05 at 12:20 PM Reply With Quote
welll
if i was you i fill it up with water one thing is for sure... the petrol will rise
when you are at the top i would just test
with a bit of flame.....
petrol isn't that powerfull
and if there is still a bit of mixture..it will ignit and you even will feel it...(after you still live )
you will see a blue flame come out nothing more nothing less..
and then you are sure it cant ignit again...
atleast when putting a bit of fire on it with weld glooves on and glassen you are prepared and you know what can happen..
if you fill with water but the jigsag / aluminium explodes maybe you can then hurt your slelf because of the chock it gives you you aren't prepared then....
petrol lands on water soow all the petrol will go upwards.. (oil = 0,9 water = 1,00)
Regards,
Walter
posted on 30/5/05 at 11:26 PM Reply With Quote
Sounds like fun you will have... have you got an old fire extinguisher? Either way just be careful Chris!
ChrisGamlin
posted on 31/5/05 at 08:48 AM Reply With Quote
TKS, the main danger from explosion is petrol vapour rather than petrol in its fluid form, so if you fill it with water there's nowhere for the vapour to accumulate therefore there's no real chance of anything igniting it, even if it is floating on the top. Ive never tried it but have been told you could throw a lit match into a bucket of petrol and it wouldnt explode as long as there was little vapour coming off it at the time.
Hellfire, not what you meant I dont think but an old Halon fire extinguisher discharged into it would be another way I guess!
NS Dev
posted on 31/5/05 at 08:50 AM Reply With Quote
Filled with water it will be fine, but just make sure you have a pre-pump filter installed afterwards.
I have seen too many times modified tanks causing knackered fuel pumps due to bits of ally getting in them.
ChrisGamlin
posted on 31/5/05 at 11:40 AM Reply With Quote
Yep cheers, I have a pre and post pump filter in place already to catch those last little bits that are impossible to wash out
ChrisGamlin
posted on 2/6/05 at 07:15 PM Reply With Quote
Right chaps, Ive managed to cut the hole in the tank without blowing myself up using the water filled method but I notice that it has 6 holes to bolt it all up together. How have you lot gone about holding nuts / bolts still to do them up, or is it sufficient to just use self tappers into the tank itself and not bother with nuts? I could possibly use those sprung steel things that clamp on the edge of a piece of metal with a threaded hole on one side but having those there will probably not allow the sender to seal properly. self tappers will be better but how do you ensure a half reasonable seal around the bolt holes if using nuts n bolts?
cheers
Chris
tks
posted on 2/6/05 at 07:43 PM Reply With Quote
pfff
i have used self tappers in stainless steel
(drill first) a bit...(not all)
then i used some silicon stuff used for window changing on cars..its black and petrol doesn't change it state..etc..
Its rock solid..
Tks
ChrisGamlin
posted on 3/6/05 at 02:42 PM Reply With Quote
After thinking about it for a bit, I decided on Rivnuts (I forgot I bought the tool a couple of weeks ago!). I needed to use M4 rivnuts though as M6 are too bulky and dont allow the rubber gasket to sit on top of them and seal. I smeared a little instant gasket on the rivnuts before putting them in and have bolted it all up and tested it with water, it all seals fine.
cheers
Chris
James
posted on 6/6/05 at 04:02 PM Reply With Quote
Chris,
Ali or steel rivnuts?
Have gotta do something similar myself.
James
ChrisGamlin
posted on 6/6/05 at 04:17 PM Reply With Quote
I went with ally because
a) thats all I had
and
b) cos I figured steel ones might react with the ally tank.
Filling with water was OK in the end to be honest, and you get so much crap in there whilst cutting that if you didnt want to use water you'd need to use about 5 gallons of petrol to wash it all out again
ChrisGamlin
posted on 6/6/05 at 04:21 PM Reply With Quote
There was another way I thought afterwards of doing it if sealing over the rivnuts is an issue. What you could do is to make up an aluminium ring with the 6 holes in it for the sender, put rivnuts into this ring, then put a cut in the ring so you can feed it inside the tank through the smaller hole. Pictures / 1000 words etc
Rorty
posted on 7/6/05 at 03:53 AM Reply With Quote
Just like this: split ring
Cheers, Rorty.
ChrisGamlin
posted on 7/6/05 at 10:28 AM Reply With Quote
Thats the chap
indigoglyph
posted on 16/6/05 at 08:43 PM Reply With Quote
Cutting my ring to make it split worked for me, too (VDO sender). Pics and a description are at http://mdround.blogs.com/striker/2005/01/index.html
ayoungman
posted on 17/6/05 at 10:04 AM Reply With Quote
Two things to add.
1) I spent a nervous 2 hours welding a 100 ltr landrover fuel tank .I had it filled to the top with water but I was still cacking myself each time I pulled the Mig trigger !
2) A bloke near me blew himself and his garage to pieces doing a fuel pump change ! It closed the A2 for 30 hours.
Petrol and petrol vapour can and do kill !
"just like that !"
tomm
posted on 17/6/05 at 11:29 PM Reply With Quote
Use a Chisel to start a hole at centre of required hole and use a pair of tin snips - easy peasy, good luck !
stevebubs
posted on 18/6/05 at 12:04 AM Reply With Quote
cheers
Chris
Chris,
Just seen the thread. This is exactly what I did with mine a few weeks ago.
Stephen
<<  1    2  >>
