Author: Subject: Sierra Diff back plate
smart51
posted on 4/6/05 at 02:05 PM Reply With Quote
Damn. I have to grind off the rear mounting point on my sierra LSD to get it into my chassis. Guess what I've gone and done. Can the hole be patched up in any reliable way (I can't weld and don't want to learn). Are all sierra diff back plates the same? If so, Can I bolt one on from another diff? Does anyone have an old diff (an non-working one say) ?
carnut
posted on 4/6/05 at 02:21 PM Reply With Quote
I did this too. I just took the diff down to a local garage to be welded up.
dnmalc
posted on 4/6/05 at 03:00 PM Reply With Quote
Smart 51 I have a spare diff sitting in the garage off of a 1.6 yours free if its of use. please holler
smart51
posted on 4/6/05 at 04:53 PM Reply With Quote
dnmalc,
Where are you based?
smart51
posted on 4/6/05 at 04:57 PM Reply With Quote
Tip for those who need to cut off the rear mounting lug on their sierra diff:
cut from the top at about 45° towards the back. Don't cut down vertically!
Cut a little off at a time.
There is enough meat on the back plate to drill and tap 2 holes and put a plate over the hole, with a suitable adhesive to make it oil tight. will this be good enough? does the diff get hot? is PU adhesive or epoxy attacked by oil?
Dillinger1977
posted on 5/6/05 at 04:20 PM Reply With Quote
cheers for the tip! i might have to do this soon!
im building an RT and havent got round to fitting the dif yet, but visually i reckon that rear mount should be above the round bar at the rear.. is this not the case?
or does it need trimmed to actually get the thing in there?
oh ive just noticed your using an LSD, does this differ in shape to a 3.36 open diff?
-Rog
smart51
posted on 5/6/05 at 04:50 PM Reply With Quote
My diff had a big aluminium boss sticking out of the rear at the top with two threaded holed in it for mounting bolts. The diff has to go in nose first from underneath. This boss fouls on the lower chassis rail. I looked to see where the boss touched the diff and cut downwards from there. Mistake. Because the diff goe in nose up at an angle, an angled cut is sufficient to clear the chasis rail. Probably.
