Author: Subject: watts linkage mounting points
Cousin Cleotis
posted on 7/6/05 at 07:05 PM Reply With Quote
should the two outer mounting points of a watts linkage mount on the chassis or axle?
Thanks, Paul
Neville Jones
posted on 7/6/05 at 07:14 PM Reply With Quote
I've read that it saves unsprung weight if the outers are on the axle and the bellcrank is on the chassis. I think this is how the early Ford rally cars were configured.
posted on 8/6/05 at 07:45 AM Reply With Quote
Doing it one way the roll centre is constant wrt ground level the other way it constant wrt the cars cg -- dosen't make much difference all depends on how easy it to provide decent stiff mountings.
My person choice would a horizontal linkage Malllock style with the bell crank under the diff.
[Edited on 8/6/05 by britishtrident]
Volvorsport
posted on 8/6/05 at 11:06 AM Reply With Quote
glad to hear somebody else is doing the watts linkage .
mine is using the chassis for the centre mount , axle for the puter points - be warned the lower tube may foul the chassis on droop /roll , so make sure youve got clearance , ill post some pics later in the week , when i have it finished .
www.dbsmotorsport.co.uk
getting dirty under a bus
posted on 8/6/05 at 03:01 PM Reply With Quote
Yes please sounds interesting :-)
Volvorsport
posted on 9/6/05 at 07:54 PM Reply With Quote
links to pics as promised
http://homepage.ntlworld.com/mj.slater2/Phot0036.jpg
http://homepage.ntlworld.com/mj.slater2/Phot0037.jpg
http://homepage.ntlworld.com/mj.slater2/Phot0038.jpg
http://homepage.ntlworld.com/mj.slater2/Phot0039.jpg
apologies if theyre not up to scratch quality wise
Glan Noye
posted on 9/6/05 at 11:06 PM Reply With Quote
I was considering a Watts linkage until I came across this http://not2fast.com/chassis/mumford.shtml Now I have too many choices!
Cousin Cleotis
posted on 11/6/05 at 01:21 PM Reply With Quote
thanks for the help and the pictures.
Paul
NS Dev
posted on 14/6/05 at 12:16 PM Reply With Quote
If you don't mind the extra work and designing it, then the mumford link is a VERY good way of locating a live axle, in fact the principle is the only one that allows easy adjustment of the roll centre height with a live axle.
