Danozeman
| posted on 9/6/05 at 08:15 AM |
Steering downlink again..
Morning. I know thiis has been covered many times but i cant find anything relelvant. The sierra downlink i have is in two sections. Is this the
right one to modify? Im thinking not..
Dan
| posted on 9/6/05 at 08:37 AM |
istr that the two part one is off a P/S rack. is the splined end the right size for a manual rack?
i have the correct one if you want (i think!).
| posted on 9/6/05 at 09:06 AM |
Does it have a short extension and a longer one. I found an adjustable column that had that setup. You can use the top off one and the bottom off the
other if you only want one piece or just extend one piece of it and still use both bits, either works.
Danozeman
| posted on 9/6/05 at 07:12 PM |
It came off a non adjustable manual rack. It does have a shorter and longer bit with a join in the middle. I had trouble getting it off the rack so
maybe it was on the wrong one.
Joel p u say u have the right one?
Dan
| posted on 9/6/05 at 08:08 PM |
unfortunately not, turns out its got power steering. sorry mate.
