chris101
| posted on 9/6/05 at 02:09 PM |
Where to get bushes??
anyone know where to get bushes for the BYOSC book car?? been surfing the net and havent found anywhere.
cheers
flak monkey
| posted on 9/6/05 at 02:52 PM |
Most people use polybushes now. Thats fine if you buy your wishbones and polybushes from the same supplier. GTS, MK, Luego, Tiger and MNR all use
polys AFAIK. If you are planning on building your own wishbones. Buy the bushes first or find out what size they are before you do!
Sera
http://www.motosera.com
chris101
| posted on 9/6/05 at 02:56 PM |
cheers,
will look into buying some wishbones i think. more accurate!
flak monkey
| posted on 9/6/05 at 02:59 PM |
I just got a set from GTS...top stuff . But then everyone will have their own opinions as to who to get them from...Maybe I'm biased
Are you planning on building your own chassis? If so it doesnt matter that much where you get all the suspension stuff from as you can make it
fit...If you plan on building a kit, then probably wise to buy it all from one place...
Sera
chris101
| posted on 9/6/05 at 03:09 PM |
build my own. cant afford the kit! plus will be good experience.
splitrivet
| posted on 9/6/05 at 03:55 PM |
Got mine with the bushes and bush tubes/ inserts from lolocost but GTS etc etc all supply the same,as David says though buy em before you start
making the wishbones.
Bob
