Author: Subject: Securing the stearing rack
ditchlewis
posted on 10/6/05 at 08:56 AM Reply With Quote
I am wondering what is the best way to secure the stearing rack in my MK
I am nearing completion and I have for some reason left this late. Is it best to lockwire the nut to part of the chassis, of will i get away in the SVA with Nyloc nuts?
What does anyone else think?
DarrenW
posted on 10/6/05 at 08:59 AM Reply With Quote
I think Nylocs are the norm.
Are your brackets OK? Man enough to stop rack movement?
ditchlewis
posted on 12/6/05 at 08:36 AM Reply With Quote
I have used the rack supplied with the kit and the mounting plate is as shown above. i have used the strongest bolts i could buy at the local fixing specialist.
DarrenW
posted on 13/6/05 at 08:16 AM Reply With Quote
Hi Snoopy,
Im no chassis expert, thats why i bought one. I cant really compare. Your pic looks Ok to me. Do you think mine looks OK? (you are more of an expert than me). All i know is that a mate of a mate of mine had problems due to rack movement and i was told had to strengthen the plate. It may just be a one off problem and was easily fixed. I dont know what rack was used or how it was mounted - maybe it wasnt a std set up. I only posted the reply as it may give some people that are concerned about vague steering an idea where to look (i dont mean just Mk owners - i mean se7en builders in general)
Only experience i have had in this area is with a Mk1 Golf GTi that i rebuilt / uprated a while ago. I tried to get away with the original rack mounts but steering was a bit vague. I had to fit stronger bushes to control the movement. The se7ens should be much better as they are all solid mounted to the chassis. As long as the brackets / plates are rigid, as you say all should be OK. The problem i have been made aware of may have been a one off incident. Maybe this is a good point for locosters to be aware of when they make their own chassis, ie ensure the brackets are strong and rigid. Iam sure you will agree with me that this is one area that needs to be right.
Thanks for the pics and clarification.
Darren.
posted on 13/6/05 at 12:13 PM Reply With Quote
Only if the chassis is deigned to accept the cut down Sierra rack. The Escort rack as used in the book design is rubber mounted (though you can probably buy solid mounts for it).
NS Dev
posted on 13/6/05 at 12:29 PM Reply With Quote
yes you can!
Scotty
posted on 13/6/05 at 12:41 PM Reply With Quote
ns dev
have you got a contact for the brackets
PLEASE NOTE! All comments made by this person are to be considered "Tongue in Cheek" and are not meant to be taken seriously in any way - so there!
NS Dev
posted on 13/6/05 at 12:44 PM Reply With Quote
Yup,
rally design,
Rally design ally rack clamps - click here!
Scotty
posted on 13/6/05 at 02:24 PM Reply With Quote
nice one, thanks
just ordered a set
