Author: Subject: f27 suspension setup/Ride height
westf27
posted on 17/6/05 at 12:29 PM Reply With Quote
With my suspension adjusted to manufacturers spec giving 4 inch clearance which i assume to be bottom chassis to road,the wishbones and track rod angle up towards wheel maybe 5/10 degrees.5 inch clearance makes them horizontal.Which is correct?Also anyone know how to correctly size the length of dampers and springs?
thanks to david for his input
robj
posted on 17/6/05 at 02:16 PM Reply With Quote
F27 suspension setup
I feel you need to raise your ride height so that the lower wishbone is horizontal. Check that your lower ball joint is tight as this can also make a difference. If your lower wisbone is horizontal then idealy you want your top wishbone running down from the top of the stub axle to the chassis.
