shades
| posted on 20/6/05 at 10:53 PM |
nfauto plastic fuel tank?
Has anyone fitted/used the "small" plastic fuel tank from nfauto? Can it be used with fuel injection with the small "surge
well" inplace of a swirl pot?
mookaloid
| posted on 21/6/05 at 06:51 AM |
There have been a lot of problems with plastic tanks leaking.
I would avoid them.
Mark
JonBowden
| posted on 21/6/05 at 08:04 AM |
If you can get one to not leak, It should be less likely to split during a rear end shunt - ie should be safer.
If you watched A Plane is Born, the guy demonstrated how tough the plastic tank in the Europa kit is.
Jon
shades
| posted on 21/6/05 at 08:56 AM |
I am asking cos I got a steel one with my avon kit, which has been lying in the loft rusting for the past year. Am toying with upgrading to an alloy
or plastic one.
I need one with a swirl pot for my fuel injection. Whats the latest sources. I read some archive posts last night with variaous conflicting posts on
plastic tanks. Thought I would just see if there was any update.
andyace
| posted on 21/6/05 at 11:44 AM |
GTS Do them :
http://www.gtscougar.freeserve.co.uk/chassis.htm
ChrisGamlin
| posted on 21/6/05 at 12:45 PM |
It was the "glue'd" tanks that fell apart, the GTS / NFAutos ones arent made the same and should be fine.
shades
| posted on 21/6/05 at 04:51 PM |
is the small sump in the bottom any use for use with fuel injection pump though?
