Author: Subject: Shock abs. part no's
Danozeman
posted on 23/6/05 at 10:59 AM Reply With Quote
Morning, lovely day.
Does any one know the part no's of the Gaz shocks for a locost?
Dan
andylancaster3000
posted on 23/6/05 at 11:19 AM Reply With Quote
I've just bought some from ebay. They're a couple of inches shorter than what the book says at 12"open 9"closed, but when lined up they seem ok (on a book locost). There doesn't seem to be any part numbers on the boxed but stamped on the dampers is 130-085 B12 E12. The B12 and E12 may be wrong as they are slightly covered by a sticker I can't get off without damaging!
Hope this helps,
Edit: If you look on ebay there a lots of brand new sets of 4 at about the right length, dyno tested (with dyno result sheet included) with a c spanner, going for about £150.
[Edited on 23/6/05 by andylancaster3000]
andylancaster3000
posted on 23/6/05 at 11:25 AM Reply With Quote
For example these 14"X9.5" units:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=40192&item=7981394916&rd=1
Andy.
NS Dev
posted on 23/6/05 at 01:07 PM Reply With Quote
problem is if you use dampers that are too long in terms of "open" length, the transit balljoints on the top wishbones will run out of travel before you hit the droop stop, causing damage with potentially nasty consequences!!!
DavidM
posted on 23/6/05 at 06:21 PM Reply With Quote
It depends on the positions of your brackets. Set the car at it's normal ride height and measure the bracket centres. This will give you the mid travel length for the shocks you need. If you are buying new tell Gaz this dimension and they will be able to tell you what length you need. Typically if it is 11.5" then for instance you could use 10" closed 13" open.
The back often requires a different length to the front.
Proportion is Everything
posted on 23/6/05 at 06:31 PM Reply With Quote
Was a thread on this a couple of months back apparently some makes of Tranist drag link have a more articulation than others.
Danozeman
posted on 23/6/05 at 07:30 PM Reply With Quote
MM I hadent considered the travel in the ball joints.
Dan
NS Dev
posted on 24/6/05 at 11:01 AM Reply With Quote
This is a load of crap!!!! The mid point is totally irrelevant!!!!
You need the open length of the shock correct to stop the "suspension linkages" (whatever they comprise of!) running out of travel, and the closed length to do the same in the opposite direction.
Ride height you consider afterwards, as this is set by spring platforms!!!!!!!!!!
[Edited on 24/6/05 by NS Dev]
DavidM
posted on 24/6/05 at 12:09 PM Reply With Quote
I'm sorry you disagree, but this is the advice given by GAZ. I'm assuming as they make shock absorbers they probably know something about them.
Obviously you would need to ensure that the total length of travel is within the boundaries of your suspension, but the bump and rebound travel of the shock should be equal each side of the ride height.
