The Doc
| posted on 25/6/05 at 05:46 PM |
GTS Shock Problems
Has anyone else had problems with GTS shocks (apart from the fact that they take an aeon to arrive). Just fitted mine to find that one of the front
dampers aint damping. No resistance at all, just a spring action. I can tell this by operating by hand. Not sure about the rears yet as they
aren't so easy to work up and down (higher rating etc). I've emailed Darren at GTS and am hoping for a replacement unit.
| posted on 25/6/05 at 06:28 PM |
no trouble with mine, i got them before he got so busy so there was no delay!
Ben_Copeland
| posted on 25/6/05 at 09:00 PM |
I talk to darren a lot and i've not heard of this problem before. Must be a one off. Sure he'll sort something out.
He's had to change supplier because he was messed around big time by his last supplier. Hence the delay on them recently.
Hope everything is sorted ok for you.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
The Doc
| posted on 27/6/05 at 08:01 PM |
Problem Sorted
Just for the record - I got some advice back from darren and it turned out that the problem lay in the units having been left horizontal for some
time. Took the spring off the offending unit, 'worked it' several times and hey presto it's now fine.
