niceperson709
| posted on 26/6/05 at 10:05 PM |
Dedion tube positioning
Hi Folks
I've been offered the rear end out of a 180b Datsun and as it is an independant jobbie I have been thinking of using it in my +50 Locost as a
replacement for the live axel that I have already fitted by using a de dion set up and my question is this is there any reason why I can't site
the de dion tube higher relative to the axel line so it is say in line with the top of the side links rather than the center as is the more usual
arangement , This way I could retain all of my existing suspension links as they are now , including the panhard rod and not have to alter the rear of
the chassis ( made as per the book ) . I am not to concerned about the Ratio of the diff and these units have a bomb proof reputattion so should
easily be up to the job .
I have spent a bit of time looking through the archive but as far as I can see no one has deviated from a tube placement centered between the side
links .
Best wishes
Iain
Best wishes IAIN
life is not the rehearsal , it's the show so don't sit there thinking about it DO IT NOW
http://iainseven.wordpress.com/
Bob C
| posted on 27/6/05 at 11:15 AM |
2 things
1) dedion "strut" must be horizontal at ride height
2) roll centre (if you believe...) is at height of strut in middle of car - is that where you want your roll centre???
Bob C
Bob C
| posted on 27/6/05 at 11:16 AM |
I mean panhard rod - sorry
Bob
Bob C
| posted on 27/6/05 at 11:17 AM |
and it'snot that you wanted to move.
I'll get me coat....
Bob
niceperson709
| posted on 27/6/05 at 01:01 PM |
Hi Bob
One of the rasons that I wanted to do it the way I discribed was to maintain the panhard rod being level at ride hight as you have clearly worked
out . I thend to think that there is no reason not to do as I have sugested . thanks for the input Bob
Best wishes
Iain
Best wishes IAIN
| posted on 27/6/05 at 04:40 PM |
It will work - you might have to set it with a tiny bit more toe-in and negative camber than the conventional design.
niceperson709
| posted on 27/6/05 at 09:55 PM |
"It will work - you might have to set it with a tiny bit more toe-in and negative camber than the conventional design."
just one small question why would it be any different to any other set up ?
Best wishes
Iain
Best wishes IAIN
