Author: Subject: Vented or solid ?
Paul (Notts)
posted on 13/7/05 at 06:34 PM Reply With Quote
Vented or solid ?
Time to sort out the front brakes on my Viento.
Just got a price from MAC#1 for willwood four pot callipers but they only stock solid disc types.
will these be OK for the weight of a V8 viento est 500 - 550 Kg
Vented types cost more but are they worth it ?
tks
posted on 13/7/05 at 07:49 PM Reply With Quote
would go vented...
500-550 with V8?
optimistic??
its only 100Kgs more of an Velocity??with bike engine?
think you need to calculate with 700Kgs
Fuel Full, 2 persons.. etc. etc.
Tks
bimbleuk
posted on 13/7/05 at 07:55 PM Reply With Quote
I agree I was at RAW today and the supercharged V8 Striker they built recently for a customer came in at 700kg all up.
Paul (Notts)
posted on 13/7/05 at 08:04 PM Reply With Quote
I view the weight of the car as i view my own weight
a lot less than it realy is
Paul (Notts)
posted on 13/7/05 at 08:06 PM Reply With Quote
There again. We are not realy talking about weight but MASS
Weight and mass are two different things.
One is a scaler quantity mesured in Kg
the other is a vector quantity measured in newtons
Stu16v
posted on 13/7/05 at 08:09 PM Reply With Quote
Either way, you need to be able to stop it...
Paul (Notts)
posted on 13/7/05 at 08:11 PM Reply With Quote
would like it to go first!!!!!
ady8077
posted on 13/7/05 at 08:23 PM Reply With Quote
Hi Paul
MNR do wilwood powerlite kits that use vented disks
Adrian
Paul (Notts)
posted on 13/7/05 at 08:45 PM Reply With Quote
Thanks Adrian, will try get in touch with them for a price.
Paul
posted on 13/7/05 at 11:19 PM Reply With Quote
Originally posted by ady8077
Hi Paul
Adrian
I believe they are to fit the Sierra Hubs too.. Regarding the weight of 500~550... our's has a bike engine and is 506Kgs fully loaded. I would consider hitting within 100Kgs this weight with a V8 a pipe dream.
[Edited on 14-7-05 by Hellfire]
NS Dev
posted on 14/7/05 at 07:02 AM Reply With Quote
Stu, what do you use on your car (the locost), out of interest. Still not decided on vented or solid for mine yet and performance/weights should be similar.
cheers
Nat
bimbleuk
posted on 14/7/05 at 09:41 AM Reply With Quote
Personally I'm sticking to solid 240mm discs and light 4 pot calipers. I was speaking to Bruce at Raceleda and that the route he advises on 500kg cars.
The theory is get the disc up to working temperature quickly so less mass in the disc helps this.
smart51
posted on 14/7/05 at 12:19 PM Reply With Quote
vented or not vented, for the same area of brake pad against metal you get the same braking effort. Solid discs may fade more if they overheat. The vent in ventilated discs cools the discs, reducing fade.
Vented discs weigh more because they are thicker. this makes your car slower to accelerate and decelerate (slightly).
A seven, being an opened wheeled car, will have good brake cooling as it is and so vented discs are less neccesary.
Discs only heat up by being used a lot. That is by slowing a lot of mass from high speed to low speeds very often. Sevens don't have a lot of mass and so need vented discs less. If you are planing on serious racing then vented discs may be for you. For a road car then lower weight of solid dics may be more benificial than the vent in ventilated discs.
tks
posted on 14/7/05 at 06:19 PM Reply With Quote
are the diameters the same?
pff
i would go vented....
on 700Kgs the 3Kgs difference on your disk don't gonna make allot of difference?
do you think?
Tks
posted on 14/7/05 at 09:21 PM Reply With Quote
its unspring weight, so 3kgs might even be noticable.
i was gonna forward the argument for solid discs, but wouldnt have worded it so well! But i would use solid if i could be arsed changing them
