Dale
| posted on 20/7/05 at 11:47 AM |
Brake travel?
I am in the process of setting up my top mount pedals (mgb pedals on my own brakets). I have around 20 -25 mm of travel at the point where the pin to
go into the master cylinder goes. Is this enough movement ( I can get around another 5 mm or so but it starts to put the pedal travel farther than I
would like. I have a couple of different types of master cylinders and they all have about 40 mm of piston travel.
Is this the normal amount?
Dale
Dale
my 14 and11 year old boys 22
and 19 now want to drive but have to be 25 before insurance will allow. Finally on the road
JAG
| posted on 20/7/05 at 12:30 PM |
You should really try to get the full mastercylinder stroke from the pedal set-up.
If you have brake fade at some point you will WANT to be able to push further and still get some more braking effect.
Justin
Dale
| posted on 20/7/05 at 01:47 PM |
I will have to play with it I guess as I am using the ratio (around 6.5 to 1) that the car came with I just dont know how much pedal travel the mgb
had to start with. I would prefer to keep the brake pedal movement to 6 inches or less.
Dale
Dale
