suparuss
| posted on 30/7/05 at 09:31 PM |
gts poly bushings
prolly could just email em and find out but some of you prolly know so thought id ask here-
is the 36 piece poly bush set counting the poly bits seperate cos they are in 2 pices or as one piece?
in simpler terms is it 18 individual polybushes or 12? just a bit unclear, and the pics and pdf dont work either
cheers,
Russ.
tom_loughlin
| posted on 30/7/05 at 10:10 PM |
by 36, as far as i know, it means that there are 36 bits of plastic - enough to make 18 individual joints, and 18 steel tubes for the inserts - thats
what is on mine anyway - 4 units for eash front side, 4 each for the trailing arms, and 2 or the panhard rod - i have a couple of spares.
Hope to help
Tom
Danozeman
| posted on 31/7/05 at 10:02 AM |
Should be as tom says mate. Thats what everyone else sells them as.
A whole cars set.
[Edited on 31/7/05 by Danozeman]
Dan
suparuss
| posted on 31/7/05 at 12:20 PM |
cool cheers chaps, should be enough for for with a couple spare if a i use rod ends here and there.
any idea what size tube they go into? is it the same as a book locost?
Thanks,
Russ.
| posted on 31/7/05 at 02:39 PM |
No, it's quite a bit larger than the book tube, don't know the dimensions of the top of my head, will have a measure later. It is the
same size as Luego use though (and probably most of the others I expect).
Darren told me he can supply suitable tube if needed though.
suparuss
| posted on 31/7/05 at 06:55 PM |
sound, ill drop em a mail when im ready and buy the bush and tube together.
cheers,
russ
