violentblue
| posted on 5/8/05 at 02:45 AM |
Book Suspension Basics
1 dumb question.
the suspension as laid out here I assume uses the sierra spindles, or is this
setup for the escort?
Living in canada, we don't exactly have the same cars and parts as you do in the UK.
Now my intention is to use a zetec engine for motivation, but it the Mazda rx7 a decent donor for suspenson bits? I like the big brakes on the RX7
turbo, so thought I'd simplify things by starting with its bits.
anyone have the modified drawings?
a few pics of my other projects
chrisf
| posted on 5/8/05 at 03:11 AM |
I think your question is this: Does anyone have an RX-7 based suspension design they wish to share?
Did you try the NA yahoo locost group? There are some folks using the RX-7 donor over there. Also, why do you want big brakes? They will add unsprung
weight and aren't really needed with such a light car.
--HTH, Chris
ditchlewis
| posted on 5/8/05 at 08:24 AM |
Hi
I thought the book refered to cortina uprights.
I remember a thread that said that the Hyundi Stella was a rebodied ford cortina. these were available in north america so there may be a source of
cheap parts you can use.
i may be wrong but you could check the thread which was about 2 - 6 weeks ago.
hope this helps
Ditch
violentblue
| posted on 7/8/05 at 12:29 AM |
ugh Hundi is a dirty word around here.
I've been searching for some decent books on suspension, but all the ones that many refer to are not avaliable, even on special order, around
here.
oh well, I believe I have enough info to haywire a basic design together and run the numbers through a suspension analysys program tosee what needs to
be changed.
