| posted on 28/8/05 at 03:55 PM |
id this axle please!
this is the axle on my locost, it probably an escort one, id just like to make sure before i order new gaskets for it It leaks from the backplate!
cheers.
gazza285
| posted on 28/8/05 at 04:12 PM |
Looks like an Atlas axle from a Capri to me.
| posted on 28/8/05 at 04:19 PM |
how sure gazza?! did you notice the twiddly thing at the far right?
[Edited on 28/8/05 by JoelP]
gazza285
| posted on 28/8/05 at 04:34 PM |
Diff goes in the back into the axle, with a tin plate over it. Escort axles are usually English axles, which have a seperate diff housing which fits
in the front of the casing.
The twiddly thing on the right? Breather tube.
gazza285
| posted on 28/8/05 at 04:37 PM |
Ripped off from Mark Allansons archive.
[img][/img]
| posted on 28/8/05 at 04:40 PM |
looks like thats it then, cheers gaz!
| posted on 29/8/05 at 08:24 AM |
Looks like Escort MK salsbury the hand brake rod guide eye on the back of the diff is the id feature for escort axles most Capri axcles used the
Mk1/2 Cortina style hand brake cable that ran under the diff.
[Edited on 29/8/05 by britishtrident]
gazza285
| posted on 29/8/05 at 09:21 AM |
Apart from every Capri axle on sale on eBay also has the eye on the diff cover.
Syd Bridge
| posted on 29/8/05 at 09:47 AM |
Fix the leak with Hylomar Blue, no need for a gasket. Just make sure the surfaces are clean and oil free.
Syd.
gazza285
| posted on 29/8/05 at 10:04 AM |
Syd.
That's what I'd do, only trouble is a small tube of Hylomar is nearly twice as much as a gasket. Useful stuff to have around though.
| posted on 29/8/05 at 10:07 AM |
cheers guys, ive got a gasket coming off ebay, only £3. Just need to find time to fit it!
