Nitrogeno25
| posted on 31/8/05 at 10:41 PM |
pedal box
Hi, I'm trying to decide wich pedal box would be better, top mounted or floor mounted, I Also heard of some problems with floor mounted because
the master cyl. is lower than the calipers.
Opinions are welcome. Thank you.
| posted on 1/9/05 at 07:24 AM |
But the resevoir is higher than the calipers and that is all that matters.
Danozeman
| posted on 1/9/05 at 07:36 AM |
I went for floor mounted as my steering colum was in said way. I also found these easier to use.
Dan
Nitrogeno25
| posted on 1/9/05 at 01:31 PM |
I think the reservoir is higher if I mount a m/c with a remote one, but If the reservoir is integrated I'm not sure.
| posted on 1/9/05 at 05:37 PM |
well don't use an integrated master cylinder , even if yours had the reservoir attached I would have thought it an easy mod to make it remote
, using the correct type rubber hose and a couple of simple adaptors.
