Danozeman
| posted on 22/9/05 at 05:05 PM |
Avo shock bushes.
I have some avo shocks and the bushes are too small. I need to change them to take 1/2 bolts. Does anyone know if this is possible and if so where
can i get the bushes.
Dan
Dan
Stu16v
| posted on 22/9/05 at 05:42 PM |
Unusual, as 1/2" holes seeme to be pretty much universal fit...
Unless they are originally intended for a Westfield (7/16" IIRC)
As for making good - if you can get the original tubes out, you could possibly drill them out to the right size (or have someone run them out on a
lathe). Or otherwise you could always try Avo!
Danozeman
| posted on 22/9/05 at 05:46 PM |
Your right mate originally from a westy sei..
Dan
MikeR
| posted on 22/9/05 at 07:39 PM |
just contact AVO they will sell you some - I ended up using mini ones - they are a smidgen smaller than the shock length but the dia of hole is
perfect. AVO said it wouldn't be a problem.
Stu16v
| posted on 22/9/05 at 08:25 PM |
Mini bushes = 3/8" IIRC...
MikeR
| posted on 23/9/05 at 04:05 PM |
yep = your right my mistake.......... but the comment still stands, contact avo, they will sell you bushes
