rayward
| posted on 27/9/05 at 10:31 AM |
grease type for Poly bushes
what type of grease is recommended for poly bushes(between the bush and the crush tube).
cheers
Ray
Mr G
| posted on 27/9/05 at 10:51 AM |
To be honest I did'nt think any was required, however I was informed that graphite grease was the best to use to actually help get the bush into
the arm etc if it was tight.
HTH
G
indykid
| posted on 27/9/05 at 10:54 AM |
the mk build manual reccomends silicone grease. it's what i used, and haven't had any squeaks yet.
hth
tom
DarrenW
| posted on 27/9/05 at 10:57 AM |
I have been given conflicting advice on this in the past. The bushes i have used have graphite blended into the compound to eliminate the need for
grease. Apparaently when new and bedding in a small squirt of WD40 can help after dry assembly and torquing up. I have bought some bushes for my old
Golf that had a small tube of red rubber grease in them - they were a cheap aftermarket kit, i used the grease but was then plagued with squeaks for
ever more - only cured by tightening up very tight or slackening off, both not desirable.
Prepare to be told several conflicting stories!! Probs best to ring a poly bush manufacturere for their advice.
Rorty
| posted on 1/10/05 at 06:46 AM |
Polyurethane ("poly" bushes require molybdenum disulphide grease - or "moly grease", which is usually pencil lead coloured.
Except for the red stuff!
Teflon (PTFE) and Delrin do not require lubrication.
Cheers, Rorty.
