SJC
| posted on 28/9/05 at 05:51 PM |
Sierra bolt on drive shafts
Hi All
Does anybody know any contacts to get new bolt on style drive shafts for a sierra??
I have tried Fords but they can not longer get these .
Any suggestions?????
steve_gus
| posted on 28/9/05 at 07:54 PM |
forum member nsdev gave this reply to me when i asked about custom length shafts for a granada - same as sierra
Yep, pleased to be of help!
Ring Geoff Berrisford (GB Engineering) on 01270 841081. You need to tell him the lengths from the inside of each "cup" at the wheel and
diff ends (presuming you are using Lobro type shafts)
You will want the "long spline, standard" driveshafts. (he also does stronger ones and "unbreakable" gundrilled F1 spec
ones)
think price was about 80 quid each...
atb
steve
[Edited on 28/9/05 by steve_gus]
http://www.locostbuilder.co.uk
Just knock off the 's'!
matty_64
| posted on 28/9/05 at 07:55 PM |
sierra driveshafts
you could try elliston kitparts.they should be able to supply them & any other sierra bits you might need.call them on 01842 890855
SJC
| posted on 28/9/05 at 09:49 PM |
Cheers, i will give them a try, i am sure they will be able to help.
I am also after the outer section that goes through the hub, Not sure on the technical name ??
Cheers for the replys.
Dillinger1977
| posted on 29/9/05 at 07:54 AM |
one of these?
http://www.locostbuilders.co.uk/viewthread.php?tid=29855
like rocking horse poo apparently..
-Rog
SJC
| posted on 29/9/05 at 01:00 PM |
Hi
I have the flange (bit with the studs on) i am after the bit that slides through this and the drivbe shaft bolts to??
I did not think they would be that hard to get hold of..... Supprising ah !!!
matty_64
| posted on 29/9/05 at 08:07 PM |
try elliston kitparts.he has several sierra back ends in stock(disc & drum brake type) im sure he will be able to help as i have found them very
helpful in the past.just remember which side you need as they are handed.also use a new retaining nut,still avaliable from ford i think.hope this
helps.not sure how much carriage would be though.
SJC
| posted on 29/9/05 at 11:42 PM |
ok, Cheers i will give him a try.
Like you said he may have new items, worth a try.
Thanks again
