Author: Subject: is a suitable ratio available?
zzrpowerd-locost
posted on 11/10/05 at 08:43 PM Reply With Quote
is there a suitable ratio "live" axle available for a BEC?
Avoneer
posted on 11/10/05 at 09:10 PM Reply With Quote
You can get a 3.54 for the English variety, which aint half suited to a blade engine.
Pat...
zzrpowerd-locost
posted on 11/10/05 at 09:53 PM Reply With Quote
i will be running zzr1100( as if u needed a clue lol!)
Kissy
posted on 12/10/05 at 07:14 AM Reply With Quote
Not sure about the ZZR - the 3.54 is the highest available - I have a CBR thou and I have had to dismantle and go to Sierra based (3.14) deDion. I could still use a higher ratio. You need to do some sums with tyre size and drive ratios - there are postings on here with links which will help.
jimgiblett
posted on 12/10/05 at 01:14 PM Reply With Quote
If you go wide with a Capri LSD I think you can get a 3.09.
I think that is what Jasper fitted in the end to his ZX9 locost.
Jasper you still here ?
robertwa
posted on 12/10/05 at 02:08 PM Reply With Quote
Toyota corolla/celica had a wide range of live axles fron 3.36 to 4.3, some with LSD. hI'm using a celica 3.46. Huge aftermarket for lightweight calipers/rotors etc due to its use in the dwarf cars. I have a book which decodes the diff ratio fron the VIN if you need it let me know
Rob
Edit; I have seen 2.9 advertised too, although I think they are like hens teeth
[Edited on 12/10/05 by robertwa]
ChrisGamlin
posted on 12/10/05 at 06:40 PM Reply With Quote
Will top out at just over 121mph according to the gear calc spreadsheet (available for download on the Yahoo BEC list), that is assuming an 11k red line and 205/60-13 tyres, and obviously assuming the gear ratio figures are correct!
For comparison that is around 6mph lower than a blade and 4mph lower than an R1 with the same setup, so not too bad at all.
Chris
[Edited on 12/10/05 by ChrisGamlin]
zzrpowerd-locost
posted on 12/10/05 at 07:26 PM Reply With Quote
which diff is that with chris??
ChrisGamlin
posted on 12/10/05 at 08:06 PM Reply With Quote
Sorry, assumed we were talking about the 3.54 English (Escort), the highest English diff you can get
zzrpowerd-locost
posted on 12/10/05 at 08:46 PM Reply With Quote
ok cheers just checking
