Author: Subject: Steel type (grade) for suspension bit?
Tralfaz
posted on 17/10/05 at 01:33 AM Reply With Quote
Hello all,
Am looking to make (er...have made..) bits like the ones seen in the following link for my MX-5 spindles.
http://www.raceleda.co.uk/ancilliaries.aspx
What type of steel would be recommended for the 'pins' (The brassy looking bits in the photos).
Regards,
Brian
Rorty
posted on 17/10/05 at 04:17 AM Reply With Quote
Either 4140 steel or 17-4 PH stainless steel.
Cheers, Rorty.
Tralfaz
posted on 17/10/05 at 10:16 AM Reply With Quote
Thank you Rorty,
Would heat treating of either be recommended (required) after machining?
Regards,
Brian
Rorty
posted on 17/10/05 at 11:21 PM Reply With Quote
For a Locost? Probably not, but if you want a belt and braces approach, then it certainly wouldn't hurt. Both materials can be heat treated.
Cheers, Rorty.
