Author: Subject: spring rating
mkblade
posted on 21/10/05 at 09:48 AM Reply With Quote
spring rating
i trying to find out what spring rating is common for the following
mk with the de-deion rear end fireblade power.
its been suggested that 275 up front
and 175 rear.
also the shocks are different lenghts
should the shorter ones go at the front ?
thanks
simon
JAG
posted on 21/10/05 at 11:47 AM Reply With Quote
My car is a Stuart Taylor chassis with a car engine and an Escort live axle but I have similar spring rates to you.
Front; 275
Rear; 150
I also have the shorter damper (AVOs) on the front axle.
Justin
NS Dev
posted on 21/10/05 at 02:17 PM Reply With Quote
I'd take a starting guess at between 250 and 275 on the front and 140 ish on the rear, with a bike engine.
Dale
posted on 21/10/05 at 03:54 PM Reply With Quote
Has anyone measured there wheel rate. As in 200 lbs on the front of the car drops in 1 inch so 200/2wheels = 100 lbs /inch per side.
Dale
Dale
my 14 and11 year old boys 22
and 19 now want to drive but have to be 25 before insurance will allow. Finally on the road
