NS Dev
| posted on 25/10/05 at 12:00 PM |
Sierra diff output stubs vs capri atlas diff??
a long shot but has anybody ever tried to see if the splines an a capri atlas axle match those on the sierra lobro type output stubs from a "non
push in" type diff??
I know the diffs are actually very similar and that most of the ford setup tools are the same but surely it's too flukey for the sierra and
capri diffs to share the same splines!??!
Volvorsport
| posted on 25/10/05 at 12:15 PM |
are you saying , youre gona convert an atlas diff to fit IRS - or the other way round !! .
i know one chap - dave ???? , somebody or other who used to campaign chevettes , now with a rear drive corsa - converted his live axle with
granada/sierra stuff , i dont know the ins and outs - but he bought some cv/stubs etc of tim while i was at darrian cars .
so maybe it does , not much help i know
www.dbsmotorsport.co.uk
getting dirty under a bus
NS Dev
| posted on 25/10/05 at 12:23 PM |
Heh Heh!!
The reason for the question is that martin Fox (MEF motorsport, used to rally a RWD rover called Rovaru) is after a 5.1 + ratio independent rear lsd
cheaper then a Ford 9" one.
The RWD Corsa was built by Tyron Gerbez wasn't it?? Dewi Bowen's if I rember rightly!? That was at the time we were rallying the
mid-engined Nova!.........small world!
Basically I mentioned to martin that he could do just what they did on Dewi's corsa, a relatively cheap way to get a bulletproof lsd with
available ratios. hence the question whether the sierra/granada cv's will fit!
Volvorsport
| posted on 25/10/05 at 12:35 PM |
well - he used an escort atlas diff - so yeah the capri is similar - so i dont see a reason why not to do it .
to do the one off - it wasnt any cheaper - but replacement parts were a lot less - situation may have changed now - im not sure which way round it was
- but it was definietly a mix of sierra / granada .
Darrians use the granada output flange/cv in a sierra cossie stub , BMW driveshaft - with a GKN inner CV of which type i dont know - or at least the
GT car used to .
so quite a lot of stuff intermingles
give me ex boss a call , ill u2u his number
NS Dev
| posted on 25/10/05 at 12:40 PM |
I think he was talking about £6000 plus for a ford 9" lsd in unknown s/h condition so I guess he could fabricate a bit for that sort of
money!!
Will do, cheers mate.
MikeR
| posted on 25/10/05 at 03:11 PM |
don't forget you've got an atlas axle waiting to be 'examined' not far from your house!
NS Dev
| posted on 25/10/05 at 09:56 PM |
good point Mike!
Just can't be bothered with taking the sierra diff out of the 7 and mucking about taking a stub out of it to see if it matches the atlas shafts
though!!
