GTE
| posted on 30/10/05 at 06:57 PM |
Wilwood caliper problem
I've recently changed the front brakes on my Dax Rush.
I took off the Cortina calipers and put some Wilwood Dynalites on.
The problem is , that the first time I hit the brakes nothing happens; if I press the brake the second time the brakes work.
There is no air in the pipes, the only thing I can see is that the pistons in the calipers pull back.....(that's why I have to press the brake
twice)
Does anyone have a solution for this problem, because it's a little bit dangerous if you have to make an emergency brake.......
Thanks in advance,
GTE
theconrodkid
| posted on 30/10/05 at 07:16 PM |
are the front wheel bearings too loose?is the vent in the master cyl cap blocked?
who cares who wins
pass the pork pies
Stu16v
| posted on 30/10/05 at 07:19 PM |
Check there isn't excessive play in the front wheel bearings. That could cause the symtoms you describe.
However, it could also be a mismatch between new calipers and master cylinder...
Wadders
| posted on 30/10/05 at 07:54 PM |
why are you certain that there is no air left in the system? I have to unbolt the wilwoods on my car and turn them repeatedly upside down during the
bleed process this is the only way i have found to get all the air out.
Al
rayward
| posted on 30/10/05 at 08:14 PM |
have you got calipers for vented disks,but actually have solid disks???
Ray
Jon Ison
| posted on 30/10/05 at 08:19 PM |
Ide go with the wheel bearing theory, something as got to be knocking them off, did you fit new discs ? if so are they sat on square ?
GTE
| posted on 30/10/05 at 09:08 PM |
Hello,
Thanks for all the replies.
I have new solid disks, the calipers are original for vented ones but you can take out the spacers to fit them on solid disks.
I'll check out all your advices first thing in the morning.
GTE.
[Edited on 30/10/05 by GTE]
pk
| posted on 31/10/05 at 01:12 PM |
i had this problem - solved it with a 2psi residual pressure valve RalDes!
