Author: Subject: Sierra steering contacts
hector
posted on 28/11/05 at 05:36 PM Reply With Quote
SIERRA STERRING WHEEL/HORN
Can any one help??, am i right in assuming that there are 2 spring loaded contacts that press against the brass rings on the inside of steering wheel, as mine are missing, (had a friend help dismantle car and think he did not notice them when he removed the wheel), SO has anyone got some spare ones that i can purchase??
DavidM
posted on 29/11/05 at 12:40 AM Reply With Quote
Yes you are correct. Two contacts on the end of a short wire with a plug connector the other end. Should be readily available from your local scrapyard.
Proportion is Everything
hector
posted on 29/11/05 at 04:58 PM Reply With Quote
aahh, cheers for that, just need to find a scrappy with a sierra now then.!!
cheers colin
