asn163
| posted on 1/12/05 at 08:48 PM |
Wheel Offset?
For 15"x7" wheels with 195/50/15 tyres, what is the correct offset for an Indy?
ET35 or ET38?
Thanks,
Simon
donut
| posted on 1/12/05 at 08:49 PM |
ET38 springs to mind.
phelpsa
| posted on 1/12/05 at 08:56 PM |
Bang on although it really makes no visible difference!
ReMan
| posted on 1/12/05 at 09:23 PM |
But the ET35 will stick out by another 3mm right?
www.plusnine.co.uk
Phil. S
| posted on 1/12/05 at 09:49 PM |
I thought it would be the other way round, i.e. that the 35mm will be narrower
ReMan
| posted on 1/12/05 at 10:02 PM |
Just checking
www.plusnine.co.uk
RichieC
| posted on 1/12/05 at 10:18 PM |
The higher the number, the less they will stick out.
ET38 will be 3mm less than ET35
ditchlewis
| posted on 2/12/05 at 08:34 AM |
I used Et38 and they are only just inside the rear wings.
Ditch
Phil. S
| posted on 2/12/05 at 10:25 AM |
Are you sure about that? If the ofset is greater that means the back plate is further in from the centre line of the wheel, so the track will be
wider. Negative ofset has the reverse effect. So the greater the negative ofset the further in the wheel will sit.
I switched from +5 to +24mm ofset and the latter were much wider.
greggors84
| posted on 2/12/05 at 11:13 AM |
I always took a positive offset to be one where the mounting surface was further out than the centre line, like on most wheels.
The ET18 caterham wheels i tried stuck out the arches loads, the ET38 ones are much much better.
I think in the range of 35 to 38 should be fine for an Indy, any less and you will start messing with the geometry noticably.
[Edited on 2/12/05 by greggors84]
Chris
The Magnificent 7!
| posted on 2/12/05 at 11:14 AM |
Did you swap from a 5J wheel to a 7J at the same time?. It sounds like you are confusing width with offset.
tadltd
| posted on 2/12/05 at 12:05 PM |
All the info you need on wheel offsets, PCD's, etc...
http://www.turner-auto-design.com/wheeltech.htm
Best Regards,
Steve.
www.turnerautosport.com
progers
| posted on 2/12/05 at 01:58 PM |
ET 38 is the ideal offset for a 6" wheel in an Indy. For a 7" wheel you will need to increase the offset if you want the wheel outside
edge to be in the same position. In this case it will need to move 12mm (1/2" as the wheel is 1/2" wider relative to the centre of the
wheel. Thus you will need an offset of et50. In practice et45 will still fit inside the wheel arches OK, with et38 you will be almost flush with the
wheel arches which could be an SVA fail.
Paul
asn163
| posted on 2/12/05 at 08:14 PM |
Thanks guys for the info.
I have decided to play safe and have gone with 15" x 6.5" ET38 Wolfrace Street Octanes.
Simon
[Edited on 2/12/05 by asn163]
