omega 24 v6
| posted on 21/12/05 at 07:43 PM |
Capri axle
I,ve just been to look at what i hope will be my locost axle.
It's a 52 incher ( oerr ) and has already been cleaned and painted BUT someone has tried to drill out one of the studs in a half shaft ( strange
I thought they were a press fit ???) this has damaged the flange face slightly.
Could I weld the face and dress it down? I could have it machined after welding.
It has the backplates in place but the drums and gubbings are missing so what should I do find drums or fit a disc setup?
And lastly the price is definately right a bottle of fine malt and it's mines (which is nice)
russbost
| posted on 21/12/05 at 08:00 PM |
The studs just punch out, providing the damage to the face doesn't affect the fit of a new stud or the flush location of the drum on the flange
face it shouldn't matter, if there are any high spots just trim 'em off with a grinder. Can't see any way you could easily fit
discs, just find a suitable set of drums etc.
gazza285
| posted on 21/12/05 at 08:14 PM |
Disk fitting kits are widely available from most Ford Rally suppliers, try Rally Design or Burton Power for your first call, or it's not hard to
make your own kit up.
| posted on 22/12/05 at 12:33 AM |
I've read that Sierra drums and backplates will fit the Capri axle but I haven't actually tried them
| posted on 22/12/05 at 10:56 AM |
Sierra drums should fit but not the backplates, discs are the easy way out. For calipers an easy source is the Rover 600 all have rear discs a lot are
starting to hit the scrap yards just now -- in tradditional Honda style 100% reliable and sail through MOTs until the hit 10 years old. The calipers
and brackets are on these are very easy to remove.
| posted on 22/12/05 at 11:00 AM |
... and to fit them, fit spaces e.g. washers or larger nuts and screw in placing using the wheel nut.
omega 24 v6
| posted on 22/12/05 at 12:27 PM |
I don't think I'll worry to much about the studs lads and lasses.
I should have looked closer to see if they had been welded in. But one has defo been drilled out ( or attempted ). I think I know where to get a
couple of half shafts.
| posted on 22/12/05 at 12:39 PM |
PPC magazine covered fitting rear discs to the Capri axle a while ago
