joolsmi16
| posted on 4/1/06 at 05:36 PM |
master cylinder
Hi all, Iam still trying to get my clutch pushrod fixed to the pedal in a vertical position however I have now run out of thread and if I continue the
thread down the pushrod I will not have enough travel.
So can I put spacers behind the pedal box and before the M/C so the M/C is further away and will both allow my pedal position and enough travel??
NS Dev
| posted on 5/1/06 at 11:41 AM |
Yes!
You will want to make the spacer the same profile as the master cyl flange or there will be a gap behind it that goes from inside the car into the
engine bay, but other than that, no probs, just need longer bolts.
joolsmi16
| posted on 6/1/06 at 07:28 PM |
thanks dev I asctually cut a small notch in the pedal to create the clearance.
