<<  1    2  >>
Author: Subject: can I buy big metal drills
zxrlocost
posted on 18/1/06 at 02:04 PM Reply With Quote
never really had to buy anything like it before but can I buy big drills that go in to a normal drill ie they have a smaller shaft then it turns into a big drill
something like 45mm
ta chris
RichieC
posted on 18/1/06 at 02:05 PM Reply With Quote
Hi mate,
I think the type youre on about are known as blacksmiths drills. They dont go up much past about 20mm so that means your into hole cutters for that sort of size.
What are you cutting?
Rgds
Richie
flak monkey
posted on 18/1/06 at 02:09 PM Reply With Quote
Buy a set of HSS tank cutters. They will cut big holes in pretty much anything.
If you want a drill around 45mm the only ones you will find are morse taper shank ones. A normal 13mm chuck would never be able to hang on to a drill that big, and its unlikey the drill (machine) itself would cope either.
Sera
http://www.motosera.com
zxrlocost
posted on 18/1/06 at 02:19 PM Reply With Quote
alright rich Ive sent your bolts by the way
and Im cutting some alloy phoned the local metal place about some blacksmith drills so will sort that out if theyve got one
whats the tank cutters dave
ta chris
DaveFJ
If its thick metal you are drilling then you want one of these.....
hss
they cost about a grand to buy so hiring is the way - you may need to buy the appropriate bit though....
Dave
RichieC
posted on 18/1/06 at 02:21 PM Reply With Quote
ta chris
Thanks mate, tank cutters look like this.
zxrlocost
posted on 18/1/06 at 02:27 PM Reply With Quote
so do they just fit in my drill
ta chris
RichieC
posted on 18/1/06 at 02:37 PM Reply With Quote
Yeh the arbor isnt a fat diameter. Would a hole saw not go through the alloy? What sort of thickness are we talking?
Rgds
Richie
zxrlocost
posted on 18/1/06 at 02:51 PM Reply With Quote
1 inch thick
ta chris
RichieC
posted on 18/1/06 at 02:53 PM Reply With Quote
Ah righty, something fairly heavy duty then
Rich
zxrlocost
posted on 18/1/06 at 02:59 PM Reply With Quote
yep ill keep looking would like to buy a tool not rent
posted on 18/1/06 at 03:11 PM Reply With Quote
You might manage 1" thick 45mm dia with bi-metal hole saw -- if you keep well cooled and the speed right down.
[Edited on 18/1/06 by britishtrident]
posted on 18/1/06 at 03:13 PM Reply With Quote
I have a few blacksmith's drills in 3/4" & 1" - they're very hard to use in a hand-held domestic electric drill, and put a huge load on the drill. You would probably have to work your way up to the final size in increments.
BTW: 'blacksmith's drill' is a good description - they're crude and not particularly accurate.
Do a Google on Tracy Tools for a cheap source via mail order (but don't use your credit card, 'cos they charge you a bundle). Send an order with a cheque and you'll get your drill(s) back by return post - they're very good at that.
zxrlocost
posted on 18/1/06 at 03:24 PM Reply With Quote
ok ta
gustavo_brum
Junior Builder
Posts 17
Registered 31/7/05
Member Is Offline
Photo Archive Go!
Building: modified locost, chevette running gear,VW engine
posted on 18/1/06 at 03:43 PM Reply With Quote
I have a few large drill bits whose ends I had reduced to 10mm in a lathe. It´s the cheapest way to go, I think.
yep ^^^^ wot he said. you need to use them at slow speed and the can jam quite easily possibly breaking your wrist (ask me how I discorverd that).
It is far saver to use a stepped cone drill - but think you are struggling to get to 45 mm.; but those are for panels really so no use for you I guess.
andyd
posted on 18/1/06 at 04:13 PM Reply With Quote
Chris, what about getting a quote from the "water jet" guy mentioned in this thread?
zxrlocost
posted on 18/1/06 at 04:27 PM Reply With Quote
ill find out cheers mate
posted on 18/1/06 at 04:34 PM Reply With Quote
coming from another angle....what is it your trying to make?
is there another way to achieve what you need?
Nick
flak monkey
posted on 18/1/06 at 04:54 PM Reply With Quote
Ok, if its an inch thick, a tank cutter is no good..
These are though:
Available in 44mm (closest you will get) from RS item number 315-5951 and are £8.60 each, not supplied with guide drill/arbor though.
Arbor to suit is item 315-5872 and is £11.55
[Edited on 18/1/06 by flak monkey]
Sera
gazza285
posted on 18/1/06 at 05:18 PM Reply With Quote
Where the hell you buying them? Harrods?
gazza285
posted on 18/1/06 at 05:20 PM Reply With Quote
If you fancy a day out in Yorkshire I have a Rotabroach. I think the biggest bit I've got is 43mm though.
k33ts
posted on 18/1/06 at 05:21 PM Reply With Quote
i use similar to what flat monkey suggests on steel car panels should do ally ok wont be fast though
i paid more like £30-£40 for steel cutting blade
ayoungman
posted on 18/1/06 at 05:23 PM Reply With Quote
If its 1inch thick alloy, a decent tank cutter will cope. Use PARAFIN to lubricate/cool it as it cuts. This will help to stop it clogging the cutting edges. DO NOT ATTEMPT IT unless you put it in a pillar drill and clamp the work piece !
"just like that !"
trikerneil
posted on 18/1/06 at 05:29 PM Reply With Quote
Hole saw, drill from both sides, nice and slow using paraffin as coolant.
ACE Cafe - Just say No.
<<  1    2  >>
