givemethebighammer
| posted on 9/2/06 at 05:52 PM |
Which grease for propshaft UJ's?
Sure it's been asked before but I can't find the answer.
thanks
| posted on 9/2/06 at 06:17 PM |
Normal LM grease, same as wheel bearings is fine, you don't need anything special for U/Js just grease them regularly
givemethebighammer
| posted on 9/2/06 at 07:06 PM |
thanks
Stu16v
| posted on 9/2/06 at 07:49 PM |
But CV joint grease is a fabulous 'upgrade' for the joints...
givemethebighammer
| posted on 9/2/06 at 09:56 PM |
Done with LM grease now, perhaps I'll upgrade them next time
| posted on 10/2/06 at 10:57 AM |
Don't mix the two Lithium grease is ideal for the job which for main part is keeping water out.
Moly grease is ideal for sliding contact but normal "Hardy-Spicer" needle roller joints have only rolling contact -- using MS grease
will tend to make the rollers skid shortening thier life.
Also don't over grease it can burst the seals.
