the_fbi
| posted on 21/2/06 at 08:08 PM |
Sierra handbrake switch
Is it possible to get a handbrake switch for the sierra handbrake from anywhere apart from a scrappy?
I'm guessing its a DIY or find one task.
Sources appreciated.
ta
Chris
flak monkey
| posted on 21/2/06 at 08:14 PM |
Do ford not sell them anymore? I am guessing not!
Seen some universal handbrake switches somewhere which should be suitable. But damned if I can remember where I saw them.
EDIT: Found them at Premier Wiring (in the switches section) £4
[Edited on 21/2/06 by flak monkey]
Sera
http://www.motosera.com
martthefridgeman
| posted on 21/2/06 at 08:27 PM |
i had the same problem, in the end i got a micro switch from maplins and made it fit. cost about a £1
[Edited on 21/2/06 by martthefridgeman]
Arnie
| posted on 21/2/06 at 08:30 PM |
Used the one from premier wiring. Works okay but you need to make up a bracket.
Regards,
Arnie
the_fbi
| posted on 21/2/06 at 09:02 PM |
okey dokey
I'd discounted Ford but I'll give them a try first.
ta
Chris
BKLOCO
| posted on 21/2/06 at 09:04 PM |
I got one a while back from one of the kit manufacturers. Can't remember which one but I think it was either Tiger or Westfield. Check out their
sites and I'm sure you'll find it.
oliwb
| posted on 21/2/06 at 09:08 PM |
I got a new one from Tiger.....Got an old one that still works but think the spade terminal has broken off but your welcome to it if u need it....Oli.
smart51
| posted on 22/2/06 at 08:00 AM |
I bought one from Ford about 6 months ago.
