Author: Subject: Uprights, hubs and bearings (again)
mstepien
posted on 24/2/06 at 05:03 PM Reply With Quote
Do you know if 2.8 Capri/Escort RS hubs are replacable with Cortina ones (and in particular can I use Capri ones on Cortina uprights ?)
Thanks and regards,
Michal
flak monkey
posted on 24/2/06 at 05:26 PM Reply With Quote
I think the hubs themselves were the same yes, but the uprights are totally different.
I stand to be corrected though.
Sera
http://www.motosera.com
Andy S
posted on 24/2/06 at 06:09 PM Reply With Quote
Different - The Cortina stub axle is longer and hub wider accordingly. Basically means that one way or the other the sub axle nut / lock nut does not work.
But its been a while since I got them mixed up and I am not getting any younger....
Andrew
clbarclay
posted on 24/2/06 at 06:25 PM Reply With Quote
Certainly the escort and cortina use different bearings, Different stub shft diameters.
I can't remember though if the bearing overal diameters are different. If there OD of the bearings are differnet then so are the hubs.
[Edited on 24/2/06 by clbarclay]
flak monkey
posted on 24/2/06 at 06:27 PM Reply With Quote
Corrected I stand!
Sera
mstepien
posted on 24/2/06 at 07:34 PM Reply With Quote
That's exactly why I'm asking the question - inside bearings are slightly too big for cortina stubs (by about 1mm). Outside bearings are correct though.
But the funniest thing is that although hubs are (according to the seller) for RS2000/Capri 2.8, new bearings kit for Capri 2.8 doesn't fit at all - differences in diameters are much more important than 2mm.
One additional question then : should bearings fit perfectly on axle stub (I think so) or 1mm of play is standard ?
Thanks and regards,
Michal
big_wasa
posted on 24/2/06 at 08:00 PM Reply With Quote
seller ? Ive got a set of hubs that I think may be escort or capri proping up my garden fence . In need of tlc but free to a new home
big_wasa
posted on 24/2/06 at 08:01 PM Reply With Quote
Bugger forgot photo.
