jeeby_man
| posted on 28/2/06 at 10:28 PM |
collapsable steering column
Hi all
do u have to have a collapsable steering column to pass the SVA, as i have a MKII escort steering column which isn't
cheers
Ian
hector
| posted on 28/2/06 at 10:33 PM |
looks like the steering mechanism on that jalopy would collapse if you hit a daisy too fast!!
bob
| posted on 28/2/06 at 10:56 PM |
You can purchase collasable steering boss's which i believe comply with the SVA book,i seem to remember conrod fitting one to his 1st car for
the retest.
NS Dev
| posted on 28/2/06 at 11:14 PM |
Unless the SVA manual has changed (which it could have done since I last read it!) then no it doesn't have to be collapsible, but if it
isn't collapsible, then it needs to have a certain angle at the two UJ's so that in a collision the column is not deflected into the
driver.
As the steering shaft angle is fairly fixed on these cars, and pretty marginal in terms of the angles involved, I think the concensus is that
it's easier to use a collapsible column than to argue technicalities with the SVA tester.
