John P
| posted on 3/3/06 at 02:02 PM |
MT75 Hydraulic Clutch Operation
Does anyone have a detailed drawing of the adaptor necessary to fit a Saab cincentric slave cylinder to an MT75 gearbox?
Also do you know which Saab the slave cylinder should come from (900 or 9000) or does anyone have a part number.
Following another thread I contacted Burton Power but they can not supply anything for the MT75. I supose it is atually possible, all the info
I've found relates to a Type 9.
PaulBuz
| posted on 4/3/06 at 11:30 AM |
I might be wrong, but was'nt the MT75 fitted to the granada fitted with a hyd. clutch?
The one fitted to the sierra DOHC is def. cable operated. Its what i'm using
Paul
Liam
| posted on 4/3/06 at 12:35 PM |
I've made an adaptor to fit a Mondeo ST24 hydraulic clutch to my MT75 4x4. There are no mounting bolt holes in the bellhousing so my adaptor
will be bonded to the screw-in input shaft seal (from which I had to machine off the input shaft sleeve on me lathe).
I believe late scorp MT75s have a standard hydraulic clutch so maybe they have mounting holes in the bellhousing or on the input shaft seal? Could
never find out. There is a Tilton aftermarket hydraulic clutch kit for the MT75 which I found about when i saw one on ebay.
I could supply some photos of my setup if you like...
Liam
NS Dev
| posted on 4/3/06 at 08:44 PM |
can be 9000 or 900, but the common one that most use, is cheapest and that the AP race one is a copy of is this:
Saab Clutch Slave Linky
