Author: Subject: blimey - loot at the track rod angles on this!
posted on 3/3/06 at 03:32 PM Reply With Quote
http://cgi.ebay.co.uk/BIKE-ENGINED-LOCOST-KIT-CAR-KITCAR-PART-BUILT_W0QQitemZ4618139775QQcategoryZ29750QQrdZ1QQcmdZViewItem
Chippy
posted on 3/3/06 at 04:06 PM Reply With Quote
Looks like it needs a bit of sorting here and there. But if you could get it for around a grand, quite a good deal, especially if you look at all the bits included.
romer
posted on 3/3/06 at 06:17 PM Reply With Quote
Is it me, or does it look as though the engine is sitting extremely high?
stevec
posted on 3/3/06 at 06:34 PM Reply With Quote
Not only high but with a big forward lean, Probably so as to clear th L/H exhaust as it guzunder. But lots of good bits aswell eh?
Guinness
posted on 4/3/06 at 07:18 AM Reply With Quote
It does look like a lot of car for the money, might have a look at it myself.
He's noticed the engine "Please note: In response to a number of enquiries - The engine is not fitted into the cradle/chassis yet. The reason it appears to be sitting high in the engine bay, is that it is resting on a block of wood (to hold it safely). I am told that once fitted, the tops of the carbs will be below the bonnet line, and a cut out or bulge in the bonnet will only be required to accommodate the air filters. The size of this will depend on your choice of air filter."
Mike
